MichaelsB's avatar
MichaelsB
How to disable AP Isolation
Please help with this
    MichaelsB
    If you want detailed help, you have to answer the question.  What is the specific model number of the device you need help with?  Look on the name plate on the back for the model number.
      • MichaelsB wrote:
        Kitsap The model of the router is M6 Pro MR6500
        That is not one of the Nighthawk Wi-Fi 5 (AC) Routers covered by people who watch this section.
        While many questions about routers are generic and could be answered anywhere, some things need specialist knowledge.
        You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
        Mobile Routers, Hotspots & Modems
        Those things are very different from the standard Netgear routers covered in this section.
        You might like to search there for messages related to your problem.
        In the meantime you could visit the support pages:
        Support | NETGEAR
        Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
        Check for various troubleshooting tips.
        You may have done this already. I can't tell from your message.
        I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
