BerlinKhan
Aug 07, 2019Follower
How to run the M1 on mains power or battery back up without overheating the battery
Hello everyone,, I've just got the M1 to use for some Arlo cameras in my Winnabago. Unfortunately I cannot get the router to accept a charge while it's switch on as it keeps saying the battery tem...
W1lliam
Aug 07, 2019Virtuoso
With latest firmware, M1 would detect temperature of the battery and stop charging if it goes beyond temperature threshold. What you can do is to remove the battery, power up M1 via Type-C port, you can take another external battery charger to supply required power for M1, and AC power can be plugged to this external battery charger.
