maximumeffort
Dec 06, 2016Follower
How to Unlock a Sierra Wireless Aircard U330?
Hello,
I'm already familiar with the Aircard Watcher Software to help unlock
I have already obtained 3 codes for 3 Aircards that I need unlocked
Unfortunately, after the process I still get the error message "Incorrect Sim" (I'm using a USIM that is not from my provider in order to unlock)
The agent on the phone suggested to add four 0's in front of my 12 digit unlock code. Now I am wondering, for a cellphone its either 16 digits or 8 digits for an unlock code. Is it normal that my U330 codes are 12 digits long?
thank you
1 Reply
- DarrenMSr. NETGEAR Moderator
Hello maximumeffort
The code should be 8 digits and you will have to contact the ISP again to get the correct code
DarrenM
