NigelSH
May 26, 2017Aspirant
HP printer not connecting and Skype not working through DC112A cradle
I have been using an Apple Airport as my local Wifi with a cable connected Netgear DC112A cradle and Aircard 810 for internet but want to decommission the Airport and just use the cradle with a hard ...
DarrenM
May 31, 2017Sr. NETGEAR Moderator
Hello NigelSh
You will have to log into the cradle and check the for new firmware that way or if you have a cradle supplied from your ISP check with them on firmware updates.
DarrenM
- NigelSHJun 04, 2017Aspirant
Hi DarrenM,
Thanks for the advice.
I was able to check that no updates are available for my cradle.
Therefore this suggests I am running the current code and there is a bug that is preventing my HP envy priter from connecting WIiFi to the DC112A cradle.
This is the same as the problem I found on the AirCard810S when I first purchassed it which was eventually fixed by Netgear in a later code release.
Looks like there are not enough of the cradles around for worth making the same fix to the cradle firmware.
So I'm still linited to using my Airport as my local WiFi dispite having a very expensive DC112A cradle.
Regards
Nigel
