Tomderp
Nov 12, 2017Star
I need the antenna port size on the board Nighthawk M1(mr1100)US model to attach 4 externals
Hello, I would like to know the type of connectors to the numbered(1-4) antennas on the board of the device. I am attaching external antennae and need this size. I have several u.fl but they are la...
DarrenM
Nov 21, 2017Sr. NETGEAR Moderator
They should be TS9 ports on the
https://kb.netgear.com/23901/External-Antennas-for-AirCard-products
DarrenM
KarmusDK
May 08, 2018Apprentice
The antenna ports are proprietary and Netgear technical support won't tell you. Some Russians have indicated that the connectors are Hirose MS156, but they are a little bigger and won't fit stable, so you would have to press the pin down inside the socket and glue them to the board, like the Telstra lab testers did:
- TomderpMay 09, 2018Star
Yeah I saw that and tried those, they definitely are not snug. I have the case removed so I am kind of looking for another option. Thanks.
