EXaXXion
Jan 25, 2026Tutor
I solved the WIFI name problem with a factory reset
Hello,
I have the same problem, I solved the WIFI name problem with a factory reset.
But now I want to change the encryption to WP3 and the problem is the same, the "apply" button is disabled.
Also I cannot use my standard mobile PW for all my mobile router, because of a special key inside of it. How could that be fixed on the M3?
1 Reply
- EXaXXionTutor
And the next question, is it possible to use the same SSIDs for both WLAN frequencies?
