Djandrea
May 16, 2017Aspirant
Info aircard AC810-100EUS CAT 11 and 256QAM
HI , the AC810-100EUS , have lte cat11 and 256 qam ? thanks ;) if not , is possibile to unlock via firmware
- plus-skApprentice
Hi,
Yes, the AC810-100EUS supports 4G LTE Cat 11 and 256QAM.
You don't need to do any operations with router firmware.
- DjandreaAspirant
thanks , how check if my support 256qam? i live in sanremo and tim perhaps have 256qam , but nothing go = s7 edge have cat 9 :(
- plus-skApprentice
You can't do it without special software - QUALCOMM eXtensible Diagnostic Monitor. It costs more than a thousand dollars.
Or you can check it from Base Station side, if you working on mobile network operator.
