Yohaan's avatar
Yohaan
Follower
May 25, 2026
Intermittent WiFi Lag on Android When Running Delta Executor
Hello everyone,
I'm experiencing an unusual network issue on my Android phone and I'm not sure whether it's related to the device, router configuration, or the application itself.
Phone: Samsung Galaxy A55
Router: Netgear Nighthawk AX5400
Android: Version 14
Delta Executor: v2.721
Whenever I launch Delta Executor Android and start using it for a few minutes, my phone's internet connection becomes unstable. Instead of disconnecting immediately, I first notice very high latency and slow page loading. Shortly afterward, the WiFi icon remains connected but apps report no internet access for a short period.
A few things I've noticed:
  • The problem only occurs on this Android device.
  • Streaming and gaming on other devices continue normally.
  • Signal strength remains excellent throughout the issue.
  • Mobile data works fine when WiFi becomes unresponsive.
  • The connection usually recovers after reconnecting to the network.
Troubleshooting I've already performed:
  • Changed DNS servers.
  • Disabled Smart Connect on the router.
  • Renewed the phone's IP address.
  • Tested both WPA2 and WPA3 security modes.
  • Reinstalled the application.
  • Checked router event logs but didn't find obvious errors.
I'm wondering if certain network requests generated by the application could be triggering a router security feature or causing a compatibility problem with Android's WiFi stack.
Has anyone encountered similar behavior with Android applications where the connection appears active but internet traffic temporarily stops? Any suggestions for additional diagnostics would be greatly appreciated.
Thanks for your time.
  • I had this happen while using Delta Executor on Android too. For me, the lag wasn’t always caused by the executo, the Wi-Fi connection itself was the first thing to check. I restarted my router and phone, moved closer to the router, and forgot/reconnected to the Wi-Fi network. That cleared up the random lag for me. Google also recommends restarting the device/router and testing another network when troubleshooting Android Wi-Fi issues.
  • This is a classic symptom of a device's network stack or the router getting overwhelmed by a specific type of traffic, rather than a physical signal issue. Because Delta Executor is a script injection tool for Roblox, it executes third-party scripts that often open an aggressive number of simultaneous network connections (concurrent connections) or spam localized packet requests to bypass or hook into game servers.
