ShaunaRådman
Dec 11, 2017Aspirant
IP address
Hi, hope someone can help, we moved our router into a different room (same cables used) and now our smart TVs won’t connect and our iPads won’t connect. My iPhone says that it’s connected but it isn’t...
UK-based
Dec 12, 2017Luminary
I've tried to reply to you twice, including a link in both cases - perhaps that's why my replies aren't posted, or maybe there's a delay between posting a reply and it being displayed. I'm learning, so please forgive me if they all get displayed later...
Will your iPad connect and download data when you're in the same room as the router?
ShaunaRådman
Dec 14, 2017Aspirant
Thanks for replying. We called our internet providers and they are sending us a new router. They figure our router was possibly updating itself when we moved it. So it wasn’t able to update and glitched out. Go figure and it’s just our luck that it happened.
Thanks again 😊
Thanks again 😊
- UK-basedDec 14, 2017Luminary
You're welcome. Glad you got it sorted :smileyhappy:
