Herrgarman's avatar
Herrgarman
IPTV on Nighthawk M1
I have searched the web for a soloution to make it possible to use IP-TV with my nighthawk m1.
With no success unfortunately.
  • Moved to the appropriate section.
    Mobile Routers, Hotspots & Modems
    In the meantime you could visit the support pages:
    Support | NETGEAR
    Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
    You may have done this already. I can't tell from your message.
    I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
      • Herrgarman's avatar
        Herrgarman
        Is it in the future possible to change the software to make IP-TV work with this mobile router?
