andrewflowers56's avatar
Apr 27, 2018
Is it possible to change radio band of Netgear Unite Explore AC815S
Hello,
I have AT&T unlimited service that usally can only get on an Ipad, but I have managed to get a sim card and sign up for it on that and insert the sim card into the Netgear Unite Explore AC815S. I've had it for like a week, it works so far. on average i get 70ms ping and 7-13 mbps. But yesterday my speeds were a constant 50 mbps! the next day the speeds returned to normal. I Looked at the About page under setting in the att wifi manager and noticed that the "current radio band" was diffrent. Usally it would say LTE B12. But when I was getting 50 mbps It was ether LTE B7 or LTE B2, I dont remember exacly.
I looked up how I can change the band to fixed instead of auto, all I could find were people using telnet to use commands for diffrent modems. I wonder if it is possible for the Unite Explore to change the bands?
1 Reply
  • JasonN's avatar
    JasonN
    NETGEAR Employee Retired
    Hi andrewflowers56,
    You cannot change the bands through the settings of the AC815s. :]
    - Jason N
