leesteve's avatar
Jul 23, 2019
Is mr1100 a firmware upgrade possible?
I am currently using AT & T version but it is not available because it is used in other countries
There is no webpage window to select an upgrade file so nothing is possible. Is there any other way?
  • Yes, it's possible.
    Download the file (newest FW for ATT):
    "MR1100-100NAS_23113828_NTG9x50C_12.05.05.00_00_GenericNA_01.02.secc"
    and upload it using "fdt.exe".
    More informations can be found on WWW.
    • leesteve's avatar
      leesteve
      Tutor
      No I need NTG9X50C_12.05.05.00_ATT_03.12 firmware instead of NTG9x50C_12.05.05.00_00_GenericNA_01.02.secc version of the firmware
      Because I am using the MR1100 ATT model
      • FCB90's avatar
        FCB90
        Star
        Generic software works perfectly on ATT 1A1NAS and 2A1NAS devices.
        Just install it, come back and thank me.
    • nomad247's avatar
      nomad247
      Tutor
      Hello, I have a similar issue and it was recommended I too upgrade the firmware. The message you posted said more info at www but there is nothing else after the www. I googled the info, found a site but have idea how to upload using the FTD unto my router, which works every well with one except. After charging it, and unplugging the charger, within an hour, it shuts down and I cannot power it up unless I remove tha battery and put it back in. I really like this router, too bad Verizon does not have one.
      • Rambo974's avatar
        Rambo974
        nomad247 : do you plug-in an microSD card ? I have an "over heating" issue when I have an microSD card inside the M1. I suggest you to take it off (USB key too) and see if this solved the problem you have.
