BadgerOne
May 13, 2024Follower
Is my 2020 Nighthawk M1 Unlocked
Just wanted to check........ Is my Nighthawk M1 Router, used in UK with O2 provider SIM, unlocked. So, could it be used with other provider SIM without any unlocking process?
since you're in the Uk, not sure if it'll work but you can check this forum post for how they checked it on ATT's service.
1 Reply
