Chelleyh
Feb 25, 2018Aspirant
Is my mobile hotspot trash now?
I have a NETGEAR Zing™ Mobile Hotspot which my renter was using for the past year. A month ago, she said that the device couldn’t read the battery. She brought it to a Sprint store and they recommende...
JasonN
Mar 09, 2018NETGEAR Employee Retired
Hi ChelleyH,
I just wanted to check in with you and see if your issue has been fixed.
Please let me know :]
- Jason N
- ChelleyhMar 09, 2018AspirantHi! I’m not sure which category of support to choose. The device is over a year old.
- JasonNMar 12, 2018NETGEAR Employee Retired
Hi Chelleyh,
This will be under the AirCards category when you contact the NETGEAR support line.
Please me know if you need any other information. :]
- Jason N
- JasonNMar 16, 2018NETGEAR Employee Retired
Hi Chelleyh,
I wanted to check on you again and see if you have contacted the support line. :]
- Jason N
