488techfast
Aug 02, 2022Aspirant
Issue with M4300 10GBase-LR Activity
Hello, I am having issues with our M4300-48X (Layer 3) fiber uplink to S3300 - 52Port. There is currently a 1G Multi-mode fiber installed and it works with no issues. We are now upgrading the fiber...
michaelkenward
Aug 03, 2022Guru - Experienced User
488techfast wrote:
Hello,
While many questions about routers are generic and could be answered anywhere, some things need specialist knowledge. Ib tnbhis case the M4300 ix not a router. Nothing like.
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Discuss Ethernet Switches Plus and Pro Managed
I will ask the Netgear moderator to move your message.
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
Check for various troubleshooting tips.
You may have done this already. I can't tell from your message.
I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
488techfast
Aug 03, 2022Aspirant
There is nothing in there about a router, its a Managed Core Switch and currently upgrading the SFP+ 1G to 10G LR
- michaelkenwardAug 04, 2022Guru - Experienced User
Netgear has moved your message to the appropriate section. With luck you will not get some help.
- msiAug 07, 2022Luminary
There are a couple of possible things, but I might be completely on the wrong track...
The M4300 clearly shows that you have not a remainer of the previous 1G optic that would force down the speed to 1G (some SFP+ are dual rate, but SFP doesn't support auto-negotiation), but check if there is a fixed speed setting on the S3300 side.
I guess you have certainly checked that you have not only changed the installed fiber from MM to SM, but also the patch on both ends cables? Have you tried swapping the polarity of the patch cables? Have you been able to get a link with a SM patch directly connected cable between both switches? (you need a LC-UPC to LC-UPC with blue connector on both ends)
Oh, and depending on your experience with SM fiber, that might be redundant knowledge to you: But if you have green connector boots indicating APC (angled physical contact) on the switch side, that won't fly either as you need blue connectors that stand for PC of UPC (ultra physical contact). On the patch panel you might have green ports, make sure the color of the patch cable
Mixing blue (U)PC with APC can actually lead to damaged connectors if both sides are using LC connectors. In some areas for this installers prefer using E2000 / LSH ports for single mode fiber.
Those are just some ideas, but I hope they give you some pointers where to look next.
