boomer411
Aug 06, 2015Aspirant
Issues with 763S tethered to Mac OS X 10.10
I've been having two different problems with the AC763S when tethered to USB on a MacBook Air running Yosemite. 1) 10% of the time, I get a kernel panic when resuming from sleep (lifting lid). S...
boomer411
Aug 13, 2015Aspirant
Barring any one chiming in, are updated drivers available anywhere?
From further testing, the device is only recognized half the time when plugged in (with no other system updates/changes made in between).
DarrenM
Aug 17, 2015Sr. NETGEAR Moderator
Hello boomer411
I have checked and you have the latest firmware I would suggest contacting support to do some more troubleshooting to see if it may be a hardware issues with the 763s.
http://support.netgear.com/general/contact/default.aspx#tab-call
DarrenM
- boomer411Aug 18, 2015Aspirant
Thanks Darren - I will do so when time permits.
My guess would be a driver issue related to OS changes w.r.t. power management and/or USB support.
