Seandy
Aug 12, 2018Aspirant
Laptop doesn't see Nighthawk M1 intermittently.
Hi
My Dell laptop (Win10) sometimes sees my (Telstra) M1 when I start up, sometimes doesn't; restart M1 and laptop sometimes helps. Sometimes it sees the M1, I open Chrome OK and see a web page t...
Christian_R
Sep 10, 2018NETGEAR Employee Retired
Hello Seandy,
Are you on the latest firmware? Is this wired or wirelessly? Are you able to connect to your M1 with your laptop wired to it?
~Christian
- JSchnee21Sep 11, 2018Virtuoso
Sounds like an intermittant Wifi RF interference issue. Do you ever have issues where you try to log into the SSID and you know you'ved used the correct wifi password, but you get a generic error like password incorrect?
Are you using 2.4GHz or 5.8Ghz? If possible (assuming your laptop supports), disable 2.4Ghz, use only 5.8Ghz, 40Mhz, Long Range, with channel auto. If its not possible to turn off 2.4Ghz all together, then at least set the SSID's to be different networks. if you must use 2.4Ghz, use 20Mhz, Long, and choose a channel (1, 6, or 11) with the least interference.
Also check to make sure your laptop isn't putting the wifi to sleep to save power.
Certainly use USB or Ethernet tethering if possible -- but Wifi should work fine (mine does).
