vacool
Oct 04, 2016Follower
lb1111-100eus PoE standard
Is it 802.3af compliant? If so, is it better to use 48V PoE Injector (like Linksys LACPI30-EU) or connect supplied adapter via PoE adapter (like Mikrotik RBGPOE).
By the way, LB1111-100EUS is not in the model list and there is no product page. Is it fine?
- gruntpartystyleAspirant
Do we have any news on this? I am very interessted in buying one but would need to know how to power it properly...
- DarrenMSr. NETGEAR Moderator
This can be powered via adapter or POE
DarrenM
And the question is again, what PoE standard... passiv? 802.11af?
Hello vacool
Here is the user manual that should have all the info you will need
http://www.downloads.netgear.com/files/GDC/LB1110/LB111X_UM_EN.pdf?cid=wmt_netgear_organic
DarrenM
- mikrolteAspirant
