edigs's avatar
edigs
Follower
May 31, 2017
LB1111 Bridge mode not working
LB1111 works fine when connected to computer. Bridge moode or not.
If I put it in bridge mode and connect to routers WLAN, no IP is assigned.
I tried with Cisco 1812, Linksys WRT54GL,...,  no IP.
Any suggestion?
1 Reply
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello edigs
    Have you tried to disable the DHCP on the router and see if it will work that way?
    DarrenM
