thompsoncm
Mar 04, 2018Aspirant
LB1111 not starting after Poe power loss
I cannot reply to the post on this issue last year, I am not sure why, so will start another one. The LB1111 will not restart after a power interruption if using the POE power source. If using the DC...
j4y
Mar 04, 2018Guide
What POE standard are you using to power the LB1111?
You are probably referring to my post about the LB1121 awhile back about the exact same issue.
As per my post, i narrowed it down the the POE standard. Netgear's documentation is horrible and doesn't state the POE standard... It just says "POE". You would think Netgear would know that there are about a half dozen POE standards and most are not compatible with each other. Duh. Support was also useless.
For my LB1121, it will only restart properly if it is being powered by 802.3at (POE+). Nothing else worked. After getting a proper "at" power injector, all has been good!
This may or may not be true for the LB1111. Good luck
- thompsoncmMar 04, 2018AspirantActually if one does a search on Netgear Community for LB1111 or LB1121 there are quite a few POE problems being talked about. My particular issue is that though it will work via POE connected to my switch, but if there is a power interruption it will not restart. If the power is off for more than about 2 minutes then it does. As you say, Netgear's POE is not good. As far as Tech Support goes they are even worse. They do not listen to what you tell them, nor will they answer a question directly . I told them twice, and provided the link to the LB1111 POE problems on the Netgear Community and they reply by saying that there are no known issues!!! Their standard solution is to do a factory reset and if that does not work offer a RMA, which in this case does nothing as the replacement unit has the same problem. I had similar success with them over a Pro safe VPN router that I had from them, it would not do concurrent VPN and QOS. The unit just locked up, had to pull the power plug to gain access. I gave up on that issue and purchased a Cisco RV325 that works without a problem. My mistake here was to purchase another Netgear product, it will not happen again.
- JasonNMar 05, 2018NETGEAR Employee Retired
Hi thompsoncm,
We are aware of the issue with PoE on the LB1111 & LB1121. The issue has been fixed a while ago and the new units should not have this problem because the software/hardware fix for the issue was implemented in the devices.
I will PM you right now to collect your contact information so my internal team can reach out to you.
- Jason N
- thompsoncmMar 12, 2018AspirantDespite the PM, which implies that some action may take place other than asking my contact details nothing has happened.. I give up on netgear and that is the end of it.
