dma999999's avatar
dma999999
LB1120 - 4G LTE Modem - No Connectivity (Bell LTE in Canada)
Just got one of these, specifically for the bridge mode. For use in Canada on the Bell Mobility LTE network (which I understand is supposed to be compatible. Had the SIM in a Huwei hub provided by Be...
  • dma999999's avatar
    Aug 11, 2017
    My bad. Apparently this is an issue with the carrier (Bell). Unlike SIM cards for phones, those for data only devices are locked to that device's IMEI and serial number and can only be changed through Bell.
    Thought I'd perhaps mention it here in case someone else runs into the same issue.
