DanRozz
Sep 10, 2020Tutor
LB1120-100NAS conencts, then after a while can ping, but can't TCP.
Help! I'm in NYC, connecting the LB1120-100NAS to LTE. I have a great signal. I'm using the broadband APN... It seems like everything is working... Then... I have a problem that after an hour...
LlamaLarry
Sep 11, 2020Luminary
This also happens to me on my LB1120 and LB2120 modems, but it lasts longer than an hour. I ended up using a timer to restart the modems every 12 hours. Everything will be working fine and then around 10-14 hours the modem will show it is connected, but no internet traffic is passed.
Prior to using these modems I used DC112A cradles +815S hotspots using the same SIM cards that I *never* had to reboot to bring them back to life.
- DanRozzSep 11, 2020Tutor
I thought about that as a solution, "using a timer to restart the modems" but then realized that it would be better to have a reliable product that can be configured to actually work as needed. I've opened a support case... Nothing meaningful yet.
