rramse's avatar
rramse
LB1120 antenna overkill?
    Okay, first of all, I don't have any complaints about the Netgear internal antenna performance.  It works okay inside one house but in another house I need to run an external antenna because of cell tower obstructions not distance.  Two AT&T towers are located 1.5 and 4 miles away.
    My question is: are there any FCC restrictions against using a 2x24dBi parabolic antenna with the LB1120 power output?  LTE-Outdoor-Grid-Antenna
    I apologize if this question is sensitive, but I need to use 25ft of flexible RG58 and still get a good signal with an all metal antenna in 117 degrees of heat.
  • Hi rramse,
    We received a feedback from the team. It would be best to check with FCC and Local Government regarding regulations when it comes to using of these type of antennas. We cannot really answer on behalf of FCC.
    Blanca
    Community Team
  • Blanca_O's avatar
    Blanca_O
    NETGEAR Employee Retired
    Hi rramse,
    Welcome to NETGEAR Community!
    Let me check this with the team. We'll get back to you.
    Blanca
    Community Team
    • Blanca_O's avatar
      Blanca_O
      Hi rramse,
      Blanca
      Community Team
      • rramse's avatar
        rramse
        Thank you for taking the time to check with your team and supply a response.  Not all manufacturers are as courteous to their customers as Netgear.  However, I still need to know the transmitting power output of the LB1120.  It's not listed anywhere I can find.
        Maximum Power from Intentional Radiator *1
        Maximum Antenna Gain (dBi)
        EIRP (dBm) *3
        EIRP (watts) *3
        30dBm or 1 watt
        6
        36
        4
        29dBm or 800mW
        9
        38
        6.3
        28dBm or 630mW
        12
        40
        10
        27dBm or 500mW
        15
        42
        16
        26dBm or 400mW
        18
        44
        25
        25dBm or 316mW
        21
        46
        39.8
        24dBm or 250mW
        24
        48
        63
