countrywidewifi
Jan 10, 2018Tutor
LB1120 AT commands
looking for the AT command list and password for the LB1120 modem
countrywidewifi
Mar 15, 2018Tutor
any possibility of band selection in the a firmware update?
JasonN
Mar 21, 2018NETGEAR Employee Retired
Hi countrywidewifi,
Sorry for the delay. I could not find any AT commands references for your device. Please contact NETGEAR support line for further assistance.
There is a similar thread for the LB1110 and saw that you have messaged in it also.
Please update me when support has helped you. Thank you :]
- Jason N
- countrywidewifiMar 22, 2018Tutor
I've already talked to them on the phone and they directed me to try here. AirCard 77xS / 34xU is the only at info they could direct me too. if you could put it in a firmware request to have band selection like a drop down box and more than 1 could be selected would be nice. also thanks for taking the time to get in here and respond to a lot of the ?'s thats been asked realy do appreciate it.
- JasonNMar 23, 2018NETGEAR Employee Retired
Hi countrywidewifi,
I will definitely forward this idea to my internal team and see what they want to do with it. Thank you so much for the appreciation. It really means a lot. :]
- Jason N
