kooG's avatar
kooG
LB1120 AT&T stuck on 3G
Just got a lb1120 modem from unlimitedinternet4u.  Hooked it up and im getting very slow speed like 1-6 megabit per sec.  Went to check the lb1120 manager and noticed its on 3G.  Tried hard resetting the modem 3 times and same thing.  Tried factory reset still same.  The APN is set to
ATT Mobile 7 (broadband)
Name   ATT Mobile 7
APN    Broadband
Authentication   None
PDP        IPV4V6
PDP Roaming     IPV4
Checked the AT&T 4g coverage map and my location is good.  Can someone help.
