bseright
Apr 04, 2017Aspirant
LB1120 Bridge Mode - No Connectivity
Hello, Trying out an LB1120 before installing across three locations as failover devices. Using AT&T and testing behind a consumer Linksys E2500 with default settings. The LB1120 works fine using...
- Oct 24, 2017
A new firmware has been posted on the update servers that fixes the LB bridge mode issue. To update LB1120, LB1121 or LB2120 to latest Firmware log into the LB web ui and go to Settings àGeneral à Software and Reset once there select check for update and wait then simply follow onscreen instructions to update the Firmware. See below for example of how the LB2120 Firmware Info screen looks like after update. For other device just need to make sure that you are using App Version: NTG9X07C_12.09.05.27
bseright
Thanks for the reply VE6CGX. Yes, DHCP and DNS enabled. Linksys works fine with standard cable modem.
Netgear support also responded and I'll be trying some of their troubleshooting tomorrow when I have access to my ethernet adapter for my laptop and can bypass the Linksys.
Thanks again.
pwherman73
May 02, 2017Guide
Hi bseright - I have the same problem it seems. When connecting in bridge mode to a laptop, it works fine, but when I connect it to any router, I do get an IP but no traffic. Would love to hear from you when you get this resolved with the Netgear folks...
Thanks
Peter
- bserightMay 03, 2017Aspirant
Hi Peter,
I just got an RMA from Netgear last night. Once I try out the new one I'll try to remember to update this post. I do intend to eventually get a public static IP but from other reviewers online that shouldn't be a requirement for bridge mode to function - and Netgear support never brought that up.
- pwherman73May 03, 2017Guide
Hi bseright and Christopher - Thanks for the feedback. What is interesting that Bridge mode works perfectly when I connect it to a PC (Win7) - I get an external IP and traffic is flowing properly. When I connect in exactly the same config to any router, not traffic flows. I guess my question is, what's the difference? Theoretically I can configure my PC to be a router... How is it blocking one but not the other? This is using a Cricket sim on the ATT network...
On another topic or FYI - this device does not like a Project Fi sim. No APN configured and it keeps on connecting / disconnecting...
Peter, same issue here. Everything works when connected directly to my MacBook Pro. As soon as I introduce a Linksys or Netgear router between the two, it stops working. Using an AT&T business account. Looking at Amazon reviews, though, nobody else has the same issue so it must be a hardware issue (just don't understand how).
