bseright
Apr 04, 2017Aspirant
LB1120 Bridge Mode - No Connectivity
Hello, Trying out an LB1120 before installing across three locations as failover devices. Using AT&T and testing behind a consumer Linksys E2500 with default settings. The LB1120 works fine using...
- Oct 24, 2017
A new firmware has been posted on the update servers that fixes the LB bridge mode issue. To update LB1120, LB1121 or LB2120 to latest Firmware log into the LB web ui and go to Settings àGeneral à Software and Reset once there select check for update and wait then simply follow onscreen instructions to update the Firmware. See below for example of how the LB2120 Firmware Info screen looks like after update. For other device just need to make sure that you are using App Version: NTG9X07C_12.09.05.27
fishforfun
May 09, 2017Guide
In bridge mode the LB1120 is setting the LAN interface to a /32 subnet, this totally confuses the router, clearly a firmware bug in the Netgear.
Others are seeing the same thing, check this over at Ubiquiti forums:
It works in router mode because the LAN interface is set to a subnet that computes, like /24, etc... Frustraring becuse I bought the LB1110 for bridge mode, and it does not work in bridge mode with any of the routers I have tried.
- pwherman73May 10, 2017Guide
Thank you - this is helpful.
Interesting enough, when I brought the LB1120 to another location that has an EdgeRouter X SFP running v1.9.0 it works like a charm - no scripts needed. The Edgerouter Pro I'm running at v1.9.1.1...
Hope to see a firmware update from either Netgear or Ubiquiti on this...
- fishforfunMay 10, 2017Guide
I have the LB1120 and tried it on my Edgerouter (in bridge mode) with 1.9.1.1 and it did not work... Crazy, but I will try it again, maybe it is a power sequencing thing, or I forgot to reboot the modem.. I also have an LB1121 (PoE) and plan to test that on my setup.
LB1120 been running a few weeks in router mode, very solid, great speeds, but I need bridge mode to do what I want to do with it.
Hope Netgear reads this forum and takes a look at their firmware.
