bseright
Apr 05, 2017Aspirant
LB1120 Bridge Mode - No Connectivity
Hello, Trying out an LB1120 before installing across three locations as failover devices. Using AT&T and testing behind a consumer Linksys E2500 with default settings. The LB1120 works fine using...
- Oct 24, 2017
A new firmware has been posted on the update servers that fixes the LB bridge mode issue. To update LB1120, LB1121 or LB2120 to latest Firmware log into the LB web ui and go to Settings àGeneral à Software and Reset once there select check for update and wait then simply follow onscreen instructions to update the Firmware. See below for example of how the LB2120 Firmware Info screen looks like after update. For other device just need to make sure that you are using App Version: NTG9X07C_12.09.05.27
fishforfun
Jun 28, 2017Guide
Following up...
1. Downgraded Edgerouter, did not work in bridge mode.
2. Connect direct to Mac, works fine in bridge mode.
3. Tried every combo of router I own, nothing works when the Netgear LTE is in bridge mode.
- OneWhoKnowsJul 01, 2017Tutor
I'm having the same exact issue with an ERX v1.9.0
Anyone know of a router that will work with this out of the box? Or an alternative to the LB1120 that is more compatible with devices when in bridge mode?
