bseright
Apr 04, 2017Aspirant
LB1120 Bridge Mode - No Connectivity
Hello, Trying out an LB1120 before installing across three locations as failover devices. Using AT&T and testing behind a consumer Linksys E2500 with default settings. The LB1120 works fine using...
- Oct 24, 2017
A new firmware has been posted on the update servers that fixes the LB bridge mode issue. To update LB1120, LB1121 or LB2120 to latest Firmware log into the LB web ui and go to Settings àGeneral à Software and Reset once there select check for update and wait then simply follow onscreen instructions to update the Firmware. See below for example of how the LB2120 Firmware Info screen looks like after update. For other device just need to make sure that you are using App Version: NTG9X07C_12.09.05.27
pwherman73
Jul 24, 2017Guide
Below is a snapshot from the logs proving that in bridge mode we don't get the subnet on the dhcp request and a hint on how to adjust for it on the router side (update dhcpd.conf with a subnet for that network adapter). What we really need is Netgear to provide a firmware update that fixes the problem and make sure the dhcp response includes a subnet.
Dec 31 19:01:25 lakehousekok dhcpd: WARNING: Host declarations are global. They are not limited to the scope you declared
Dec 31 19:01:25 lakehousekok dhcpd: No subnet declaration for eth0 (10.130.xx.214).
Dec 31 19:01:25 lakehousekok dhcpd: ** Ignoring requests on eth0. If this is not what
Dec 31 19:01:25 lakehousekok dhcpd: you want, please write a subnet declaration
Dec 31 19:01:25 lakehousekok dhcpd: in your dhcpd.conf file for the network segment
Dec 31 19:01:25 lakehousekok dhcpd: to which interface eth0 is attached. **
- pwherman73Jul 24, 2017Guide
I've opened a case with Netgear on this. I'll keep y'all up to date.
- vronpJul 24, 2017Guide
I opened a case yesterday, two cases actually. I had a terrible first attempt and complained to Netgear. I was promised that the second case would be escalated to an engineer.
During the first case, the rep denied there was any problem at all and refused to even look at this thread. When she asked me to do MAC address cloning I knew it was time to pull the rip cord.
I will be on them like white on rice today.....
- Rudedog614Jul 24, 2017Guide
pwherman73,
Thanks for the details. Where do those log entries come from and how can I get to them?
vronp and others,
If you think it will help to get more attention from NETGEAR, my existing case on this issue is # 28692510. The latest update I received this morning after continued pushing was:
"We apologize for the inconvenience. However, we do not have an ETA yet on when will the firmware be available. Once available, it will be posted on the support site. I suggest that you check the site from time to time."
If I don't find that the USG firmware update mentioned by fishforfun works for me, I am going to return my LB2120 to Amazon while I still can. I will monitor the firmware releases and this forum to see if NETGEAR fixes the issue and then I may buy more of these.
bseright, I looked at the Cradlepoint CBA850 series, and the one that includes an LTE Modem is a bit too pricey ($679 at Amazon http://a.co/5J2yOkq) for me. Since of course my time is free and the dozens of hours wrestling with this don't count. ;-)
Thanks everyone!
Thanks for posting this very useful information.
I got a chuckle reading your post as my SSID is "lakehouse" on the wap I was using for this project.
vronp - LOL - I'm guessing your lakehouse only has horrible DSL or no internet service at all... Hence we need to deal with these things...
No DSL and no clear path to a satellite !!!
