bseright
Apr 04, 2017Aspirant
LB1120 Bridge Mode - No Connectivity
Hello, Trying out an LB1120 before installing across three locations as failover devices. Using AT&T and testing behind a consumer Linksys E2500 with default settings. The LB1120 works fine using...
- Oct 24, 2017
A new firmware has been posted on the update servers that fixes the LB bridge mode issue. To update LB1120, LB1121 or LB2120 to latest Firmware log into the LB web ui and go to Settings àGeneral à Software and Reset once there select check for update and wait then simply follow onscreen instructions to update the Firmware. See below for example of how the LB2120 Firmware Info screen looks like after update. For other device just need to make sure that you are using App Version: NTG9X07C_12.09.05.27
Coolcmsc
Sep 15, 2017Aspirant
Hi, just to say I'm having the exact same issue with a LB1110-100EUS 4G LTE (EU version) in bridge mode to the Unifi Security Gateway Router.
Looking forward to the firmware upgrade.......
Will post any solutions / info found here. Thanks for all the effort!
