bseright
Apr 05, 2017Aspirant
LB1120 Bridge Mode - No Connectivity
Hello, Trying out an LB1120 before installing across three locations as failover devices. Using AT&T and testing behind a consumer Linksys E2500 with default settings. The LB1120 works fine using...
- Oct 24, 2017
A new firmware has been posted on the update servers that fixes the LB bridge mode issue. To update LB1120, LB1121 or LB2120 to latest Firmware log into the LB web ui and go to Settings àGeneral à Software and Reset once there select check for update and wait then simply follow onscreen instructions to update the Firmware. See below for example of how the LB2120 Firmware Info screen looks like after update. For other device just need to make sure that you are using App Version: NTG9X07C_12.09.05.27
Coolcmsc
Sep 17, 2017Aspirant
Hi! Solved for me using a post earlier in this thread.
My setup is the LB1110 (european version) and the Unifi Security Gateway 3P (USG) and I too was unable to get connection in Bridge Mode.
This is what I did:-
1. Updated the UniFi Gateway to the very latest release, currently VS 4.3.49.5001150
2. Reset the NetGear LB1110 to its Default Settings
3. Connected the LB1110 (switched off) to the UniFI (switched on and connected to my LAN)
4. Switched on the LB1110
5. I now had the hoped for LTE/4G connection served to and from my LAN
6. Whoopee!
7. I then logged into the LB1110 and switched over to Bridge Mode without switching anything of or disconnecting anything (remember I had reset the NetGear to Default Settings)
7. Still working fine!
8. Phew!
9. I run my system 24/7/365 including a UPS and have not dared switching the whole lot off to see if it all starts up again OK, but it should do.
Hope this is of some use until the NetGear FirmWare update arrives.
