bseright
Apr 04, 2017Aspirant
LB1120 Bridge Mode - No Connectivity
Hello, Trying out an LB1120 before installing across three locations as failover devices. Using AT&T and testing behind a consumer Linksys E2500 with default settings. The LB1120 works fine using...
- Oct 24, 2017
A new firmware has been posted on the update servers that fixes the LB bridge mode issue. To update LB1120, LB1121 or LB2120 to latest Firmware log into the LB web ui and go to Settings àGeneral à Software and Reset once there select check for update and wait then simply follow onscreen instructions to update the Firmware. See below for example of how the LB2120 Firmware Info screen looks like after update. For other device just need to make sure that you are using App Version: NTG9X07C_12.09.05.27
Retired_Member
Sep 22, 2017I have had a ticket open for over a month. There have been at least a dozen back-and-forth exchanges. They DO reconizes the problem. They claim to have a fix through firmware. For the past two weeks they have been asking me to check for an update through the device but no updates are found. I suspect there is fix via firmware out there but netgear support is probably not communicating very well within its own ranks which is causing unneeded delays.
GaryEinstein
Sep 22, 2017Tutor
I believe they are in a testing phase of a fix and would hope to see a release fairly soon.
