bseright
Apr 04, 2017Aspirant
LB1120 Bridge Mode - No Connectivity
Hello, Trying out an LB1120 before installing across three locations as failover devices. Using AT&T and testing behind a consumer Linksys E2500 with default settings. The LB1120 works fine using...
- Oct 24, 2017
A new firmware has been posted on the update servers that fixes the LB bridge mode issue. To update LB1120, LB1121 or LB2120 to latest Firmware log into the LB web ui and go to Settings àGeneral à Software and Reset once there select check for update and wait then simply follow onscreen instructions to update the Firmware. See below for example of how the LB2120 Firmware Info screen looks like after update. For other device just need to make sure that you are using App Version: NTG9X07C_12.09.05.27
Retired_Member
Oct 13, 2017Has there been any updates to this? Any word on when the firmware update is coming out?
- rat1969Oct 15, 2017Aspirant
Hope I'm at the right place for a answer, I have the LB1120 on AT&T network with x10 router. Only problem I am having or think I am having is a Velocity hotspot will get 50mbps and the LB1120 will get 25mbps. I have tried it connected through the router as well as directly to pc. Any ideas on why speeds are so different and yes I'm using same simcard in both same location and signal strength. Thanks to anyone who can help.
