bseright
Apr 04, 2017Aspirant
LB1120 Bridge Mode - No Connectivity
Hello, Trying out an LB1120 before installing across three locations as failover devices. Using AT&T and testing behind a consumer Linksys E2500 with default settings. The LB1120 works fine using...
- Oct 24, 2017
A new firmware has been posted on the update servers that fixes the LB bridge mode issue. To update LB1120, LB1121 or LB2120 to latest Firmware log into the LB web ui and go to Settings àGeneral à Software and Reset once there select check for update and wait then simply follow onscreen instructions to update the Firmware. See below for example of how the LB2120 Firmware Info screen looks like after update. For other device just need to make sure that you are using App Version: NTG9X07C_12.09.05.27
Retired_Member
Oct 18, 2017It appears Netgear isn't willing mention when a firmware update is coming out, so I'll be returning it and buying something else. Bridge mode is the whole reason I bought this unit.
This is [redacted] and I am answering on behalf of the previous Expert. We do not know if a firmware is going to be released for this unit since only our engineering department knows that information. It will be automatically pushed to your unit. Regards, [redacted]
OneWhoKnows
Oct 18, 2017Tutor
This is extremely disappointing. My next purchases will not be Netgear related.
There's no firmware update for my Nighthawk R8000 either (security related). Every other bit of network gear that I have, even hardware that's older has been patched.
