bseright
Apr 04, 2017Aspirant
LB1120 Bridge Mode - No Connectivity
Hello, Trying out an LB1120 before installing across three locations as failover devices. Using AT&T and testing behind a consumer Linksys E2500 with default settings. The LB1120 works fine using...
- Oct 24, 2017
A new firmware has been posted on the update servers that fixes the LB bridge mode issue. To update LB1120, LB1121 or LB2120 to latest Firmware log into the LB web ui and go to Settings àGeneral à Software and Reset once there select check for update and wait then simply follow onscreen instructions to update the Firmware. See below for example of how the LB2120 Firmware Info screen looks like after update. For other device just need to make sure that you are using App Version: NTG9X07C_12.09.05.27
Retired_Member
Oct 18, 2017I just want to point out the support expert didn't say "We do not know when [...]", they said "We do not know if [...]".
¯\_(ツ)_/¯
- DarrenMOct 24, 2017Sr. NETGEAR Moderator
- j4yOct 24, 2017Guide
Bridge mode is now working for me on my LB1121 connected to a Ubiquiti USG 3 port. Pretty insane how long it took Netgear to fix this. Better late than never I guess.
- racingclub21Oct 25, 2017Tutor
is this also for the euro models? I am close to returning my new LB1111...
- saidjmaciasOct 25, 2017Aspirant
What about the LB1111; left behind?
TIA!
- ErnestTheGreatOct 25, 2017NETGEAR Employee Retired
The LB1111-100EUS model has been EOL'd so there will be no more new firmware updates for this particular model. LB2120-100EUS can be used as replacment but LB2120-100EUS does not support PoE.
- rini-klOct 26, 2017Aspirant
Is this new update (see post 10-24) also for the LB2120? I tried to update via the GUI but it reported that there is no update available!!!!
- ErnestTheGreatOct 26, 2017NETGEAR Employee Retired
rini-kl Yes this is available for both LB1120, LB1121, LB210. If you are using LB2120 if you are on the latest FW you should see the following info under firmware on the about screen.
If you were part of testing any beta FW for LB2120 it is possible that your device maybe restricted from getting the latest update. If your info does not reflect what was shown in screenshot above my suggestion would be to either contact support about it or reach out to DarrenM the AirCard mod and provide him with your IMEI and SN so it can be checked against NETGEAR’s update server.
