bseright
Apr 04, 2017Aspirant
LB1120 Bridge Mode - No Connectivity
Hello, Trying out an LB1120 before installing across three locations as failover devices. Using AT&T and testing behind a consumer Linksys E2500 with default settings. The LB1120 works fine using...
- Oct 24, 2017
A new firmware has been posted on the update servers that fixes the LB bridge mode issue. To update LB1120, LB1121 or LB2120 to latest Firmware log into the LB web ui and go to Settings àGeneral à Software and Reset once there select check for update and wait then simply follow onscreen instructions to update the Firmware. See below for example of how the LB2120 Firmware Info screen looks like after update. For other device just need to make sure that you are using App Version: NTG9X07C_12.09.05.27
racingclub21
Oct 23, 2017Tutor
I've just stumbled on this thread after trying to get a LB working with my ubnt Edgerouter. As you might imagine, it doesnt really work.
Any ideas how I can test the Beta firmware before I send the device back to where it came from?
In the meantime, I've also ordered an old Sierra ES440, see if that works properly.
Retired_Member
Oct 23, 2017By the time I got on the beta release of the firmware I was long past the return period. And of course, the firmware did nothing to fix the issue. I guess NetGear sees their way of handling subnet masks as a feature and not a bug. BTW: I had been working with support for over two months.
If you can use it outside of bridge mode it works okay.
- racingclub21Oct 23, 2017Tutor
thanks for the reply.
I'll cut my losses and look for alternatives then.
I've got the Sierra on order & also wondering if a Teltonika could do the job too.
