bseright
Apr 04, 2017Aspirant
LB1120 Bridge Mode - No Connectivity
Hello, Trying out an LB1120 before installing across three locations as failover devices. Using AT&T and testing behind a consumer Linksys E2500 with default settings. The LB1120 works fine using...
- Oct 24, 2017
A new firmware has been posted on the update servers that fixes the LB bridge mode issue. To update LB1120, LB1121 or LB2120 to latest Firmware log into the LB web ui and go to Settings àGeneral à Software and Reset once there select check for update and wait then simply follow onscreen instructions to update the Firmware. See below for example of how the LB2120 Firmware Info screen looks like after update. For other device just need to make sure that you are using App Version: NTG9X07C_12.09.05.27
DarrenM
Oct 24, 2017Sr. NETGEAR Moderator
j4y
Oct 24, 2017Guide
Bridge mode is now working for me on my LB1121 connected to a Ubiquiti USG 3 port. Pretty insane how long it took Netgear to fix this. Better late than never I guess.
- racingclub21Oct 25, 2017Tutor
is this also for the euro models? I am close to returning my new LB1111...
