bseright
Apr 04, 2017Aspirant
LB1120 Bridge Mode - No Connectivity
Hello, Trying out an LB1120 before installing across three locations as failover devices. Using AT&T and testing behind a consumer Linksys E2500 with default settings. The LB1120 works fine using...
- Oct 24, 2017
A new firmware has been posted on the update servers that fixes the LB bridge mode issue. To update LB1120, LB1121 or LB2120 to latest Firmware log into the LB web ui and go to Settings àGeneral à Software and Reset once there select check for update and wait then simply follow onscreen instructions to update the Firmware. See below for example of how the LB2120 Firmware Info screen looks like after update. For other device just need to make sure that you are using App Version: NTG9X07C_12.09.05.27
ErnestTheGreat
Oct 25, 2017NETGEAR Employee Retired
The LB1111-100EUS model has been EOL'd so there will be no more new firmware updates for this particular model. LB2120-100EUS can be used as replacment but LB2120-100EUS does not support PoE.
refosk
Oct 26, 2017Aspirant
What about the LB1110?
Can we use firmware from LB1120?
If yes, where can we get it?
BR,
RM
