bseright
Apr 04, 2017Aspirant
LB1120 Bridge Mode - No Connectivity
Hello, Trying out an LB1120 before installing across three locations as failover devices. Using AT&T and testing behind a consumer Linksys E2500 with default settings. The LB1120 works fine using...
- Oct 24, 2017
A new firmware has been posted on the update servers that fixes the LB bridge mode issue. To update LB1120, LB1121 or LB2120 to latest Firmware log into the LB web ui and go to Settings àGeneral à Software and Reset once there select check for update and wait then simply follow onscreen instructions to update the Firmware. See below for example of how the LB2120 Firmware Info screen looks like after update. For other device just need to make sure that you are using App Version: NTG9X07C_12.09.05.27
iDragon
Oct 28, 2017Apprentice
Also how can it be justified to not fix one regions products when another region gets fix?
mgandalf
Oct 29, 2017Tutor
This isn't fixed for me, unfortunately. I'm using an LB2120 in bridged mode connected to a Ubiquiti EdgeRouterX running firmware 1.9.7 (latest). The firmware on my LB2120 is:
Firmware Firmware Version: M18Q2_v12.09.163431 App Version: NTG9X07C_12.09.05.27 Web App Version: LBHDATA_03.03.103.165 Bootloader Version: Bootloader Ver: v1.0.0 Hardware Version: 08
I am having the exact same issues as described - router gets IP assigned, add the routes then the LB2120 disconnects the LAN port and the whole thing starts over again.
Please let me know if I need to provide more information.
- Mark.
- mgandalfOct 29, 2017Tutor
After studying this thread, I think my symptoms may be a bif different and so I'll post a new thread.
- Mark.
