bseright
Apr 04, 2017Aspirant
LB1120 Bridge Mode - No Connectivity
Hello, Trying out an LB1120 before installing across three locations as failover devices. Using AT&T and testing behind a consumer Linksys E2500 with default settings. The LB1120 works fine using...
- Oct 24, 2017
A new firmware has been posted on the update servers that fixes the LB bridge mode issue. To update LB1120, LB1121 or LB2120 to latest Firmware log into the LB web ui and go to Settings àGeneral à Software and Reset once there select check for update and wait then simply follow onscreen instructions to update the Firmware. See below for example of how the LB2120 Firmware Info screen looks like after update. For other device just need to make sure that you are using App Version: NTG9X07C_12.09.05.27
TM-8
Dec 05, 2017Aspirant
Always Error Software Update:
Here the Data of the LB2120:
Firmware
Firmware Version: M18QW_v07.05.170721
Firmware Build Date: Unknown
App Version: NTG9X07W_13.04.00.00
Web App Version: LBHDATA_03.03.103.159
Bootloader Version: Bootloader Ver: v1.0.0
Hardware Version: 08
Device
Model: LB1120
LB2120 Manager: 192.168.5.1
PRI Version: 23113401, 00.05
Power State: Init
Current temperature: 42°C
Can You send me a link how can i download the new Beta Firmware?
- keasleyDec 05, 2017Aspirant
Currently deployed to Afghanistan and using Etisalat.af as my LTE service provider, got the APN settings and no go on either router or bridge mode. Etisalat listed as a valid provider.
SKU: LB1121-100NAS
IMEI: 014754000019907
H/W: 1.0(0600)
Could really use it to keep in touch with family and friends and keeping my mind of certain things over here. Any update on the firmware udpate.
