bseright
Apr 04, 2017Aspirant
LB1120 Bridge Mode - No Connectivity
Hello, Trying out an LB1120 before installing across three locations as failover devices. Using AT&T and testing behind a consumer Linksys E2500 with default settings. The LB1120 works fine using...
- Oct 24, 2017
A new firmware has been posted on the update servers that fixes the LB bridge mode issue. To update LB1120, LB1121 or LB2120 to latest Firmware log into the LB web ui and go to Settings àGeneral à Software and Reset once there select check for update and wait then simply follow onscreen instructions to update the Firmware. See below for example of how the LB2120 Firmware Info screen looks like after update. For other device just need to make sure that you are using App Version: NTG9X07C_12.09.05.27
bossss7
Dec 16, 2017Aspirant
Happy to report that the LB2120-AUS (Australian version) now works perfectly in bridge mode using the latest firmaware (Image attached). This unit is connected to an FVS336Gv3 firewall.
Upgrading the firmware was a bit of a task, as I had to click the 'Check for updates' button repeatedly until it actually decided to start downloading. Just kept getting error messages before that.
Other than that, all good now! Excellent product now that it's working as intended.
iDragon
Dec 16, 2017Apprentice
Still awaiting the promised euro update, though I'm at this point not surprised it hasn't turned up yet.
- bossss7Dec 17, 2017Aspirant
Which device are you reffering to? If it's the LB2120, the EU update should be available already as the AUS update was released not long ago. Seems like the AUS and EU version are exactly the same...
If you get a 'Couldn't update your device' error, then just keep clicking on 'Check for updates' until it works. I have two devices, on of them picked up the update after 5 clicks, the other took about 50. It'll get there eventually...
- iDragonDec 17, 2017Apprentice
LB1110, ie, eu equivalent to this thread's title.
- bossss7Dec 18, 2017Aspirant
You might be out of luck, sorry. Dunno if this includes yours but it seems to be part of the same series. From this thread:
Re: LB1120 Bridge Mode - No ConnectivityThe LB1111-100EUS model has been EOL'd so there will be no more new firmware updates for this particular model. LB2120-100EUS can be used as replacment but LB2120-100EUS does not support PoE.
Message 89 of 112
