bseright
Apr 04, 2017Aspirant
LB1120 Bridge Mode - No Connectivity
Hello, Trying out an LB1120 before installing across three locations as failover devices. Using AT&T and testing behind a consumer Linksys E2500 with default settings. The LB1120 works fine using...
- Oct 24, 2017
A new firmware has been posted on the update servers that fixes the LB bridge mode issue. To update LB1120, LB1121 or LB2120 to latest Firmware log into the LB web ui and go to Settings àGeneral à Software and Reset once there select check for update and wait then simply follow onscreen instructions to update the Firmware. See below for example of how the LB2120 Firmware Info screen looks like after update. For other device just need to make sure that you are using App Version: NTG9X07C_12.09.05.27
iDragon
Dec 16, 2017Apprentice
Still awaiting the promised euro update, though I'm at this point not surprised it hasn't turned up yet.
bossss7
Dec 17, 2017Aspirant
Which device are you reffering to? If it's the LB2120, the EU update should be available already as the AUS update was released not long ago. Seems like the AUS and EU version are exactly the same...
If you get a 'Couldn't update your device' error, then just keep clicking on 'Check for updates' until it works. I have two devices, on of them picked up the update after 5 clicks, the other took about 50. It'll get there eventually...
