bseright
Apr 04, 2017Aspirant
LB1120 Bridge Mode - No Connectivity
Hello, Trying out an LB1120 before installing across three locations as failover devices. Using AT&T and testing behind a consumer Linksys E2500 with default settings. The LB1120 works fine using...
- Oct 24, 2017
A new firmware has been posted on the update servers that fixes the LB bridge mode issue. To update LB1120, LB1121 or LB2120 to latest Firmware log into the LB web ui and go to Settings àGeneral à Software and Reset once there select check for update and wait then simply follow onscreen instructions to update the Firmware. See below for example of how the LB2120 Firmware Info screen looks like after update. For other device just need to make sure that you are using App Version: NTG9X07C_12.09.05.27
iDragon
Dec 17, 2017Apprentice
LB1110, ie, eu equivalent to this thread's title.
bossss7
Dec 18, 2017Aspirant
You might be out of luck, sorry. Dunno if this includes yours but it seems to be part of the same series. From this thread:
Re: LB1120 Bridge Mode - No Connectivity
The LB1111-100EUS model has been EOL'd so there will be no more new firmware updates for this particular model. LB2120-100EUS can be used as replacment but LB2120-100EUS does not support PoE.
Message 89 of 112
- iDragonDec 18, 2017Apprentice
I queried this at time of seeing that message to DarrenM and got the following reply:
DarrenM
2017-11-01 12:42 AMThe firmware is coming to europe devices in the coming weeks.
DarrenM"
Specifically querying about the LB1110 and was reassured that it was still coming, I'm hoping this was not incorrect.
