gcimis's avatar
gcimis
Tutor
Apr 04, 2017
LB1120 Bridge Mode Web interface access
Quick question - with the modem in bridge mode and the ethernet port connected to the WAN port of a router, the WAN port of the router picks up the IP address from the cellular provider as expected.  How do you access the modem's web interface in this configuration?
      • farmware's avatar
        farmware
        Initiate
        CheesePatrol wrote:
        This doesn't work.
        If in Windows environment, us ipconfig.exe to discover IP....
        Or if ib wireless environment, use Fing app
    • vronp's avatar
      vronp
      Guide
      Bad advice/information.  This is for router mode.
      • gcimis's avatar
        gcimis
        Tutor
        In reference to the comments about doesn't work and bad advice/information.
        I have this device set up in bridge mode.
        I have a Static IP from AT&T cellular, and that static IP address is applied to the WAN port on my internal router.
        The ethernet port on the Netgear LB1120 is connected to the WAN port on the router.
        I have internet access from the LAN side of the router, so this is set up correctly.
        By setting up a static route and firewall rule on the internal router, I can still access the Netgear's web console on 192.168.5.1 from inside my LAN, so this does actually work.  I just enable the settings on the router if I need to access the Netgear, otherwise those settings are off.
