seriousolive34
Jan 30, 2019Aspirant
LB1120 LTE modem alternating signal bars lit
I have an LB1120 that was working fine, until one day the power light went orange and the first, third, and fifth signal bars are lit green, but the other ones are off (except the ethernet activity l...
Oxygene
Jan 30, 2019Apprentice
Unplug for few hours, probably faulty...
- seriousolive34Jan 30, 2019Aspirant
Tried that earlier on, with no change. Had it sitting unplugged on the shelf for a few days.
- Blanca_OFeb 06, 2019NETGEAR Employee Retired
To clarify, is it solid amber or blinking amber?
Solid amber bar : The modem is not connected to the Internet.
Blinking amber bar : A SIM card is not installed or not correctly installed or an error occurred.What happen prior the issue?
Blanca
Community Team
- seriousolive34Feb 07, 2019Aspirant
Hi Blanca_O
It is Solid Amber.
I am not aware of anything happening to the device to have caused this problem.
Thanks
