seriousolive34
Jan 30, 2019Aspirant
LB1120 LTE modem alternating signal bars lit
I have an LB1120 that was working fine, until one day the power light went orange and the first, third, and fifth signal bars are lit green, but the other ones are off (except the ethernet activity l...
seriousolive34
Tried that earlier on, with no change. Had it sitting unplugged on the shelf for a few days.
Blanca_O
Feb 06, 2019NETGEAR Employee Retired
To clarify, is it solid amber or blinking amber?
Solid amber bar : The modem is not connected to the Internet.
Blinking amber bar : A SIM card is not installed or not correctly installed or an error occurred.
What happen prior the issue?
Blanca
Community Team
- seriousolive34Feb 07, 2019Aspirant
Hi Blanca_O
It is Solid Amber.
I am not aware of anything happening to the device to have caused this problem.
Thanks
- Blanca_OFeb 07, 2019NETGEAR Employee Retired
Thank you for responding.
Can you still ping the IP address (192.168.225.1 or 192.168.5.1)?
Who is your Internet Provider?
Where did you purchase this unit?
Blanca
Community Team- seriousolive34Feb 09, 2019Aspirant
Hi again Blanca_O
I can ping 192.168.225.1, but Not 192.168.5.1.
ISP is AT&T.
I think it was from Amazon.
Thanks
- JSchnee21Feb 10, 2019Virtuoso
These models seem to have hardware failures a lot. Try a hard reset (reset button with paperclip) a few times while supplying / removing power.
But if that won't clear it, than it's DOA. Buy a new one, or replace with something better.
- jsteven1Apr 18, 2019Aspirant
Any updates on this? I'm experiencing the exact same issue with my unit.
