pthrift5001's avatar
pthrift5001
Follower
May 12, 2020
LB1120 Modem
Does the modem provide WiFi as well or does it require a router?
  • This does not have wifi built into it. You can however plug in a wireless access point through the lan cable. Also if you have a wireless router that you prefer to use, you can just use it as a modem.
