Jakedecamp's avatar
Jakedecamp
Follower
Mar 27, 2020
LB1120 No Connectivity
Hi. I have an LB1120 for my home internet because I live in a rural area. It has worked fine for about a year & yesterday just stopped. Did a factory reset multiple times with no luck. None of the connectivity bars are lit up. Only power light is on. It says my data is turned off, but it’s not. No one has tampered with it at all. Any thoughts or suggestions? Thanks in advance!
1 Reply
  • JohnPeng's avatar
    JohnPeng
    NETGEAR Expert
    Based on the message, it is related to your AT&T data plan. Could you please check with AT&T on your account or try the SIM card on another device to see whether it works?
    Thanks
