FestiFiGreg's avatar
FestiFiGreg
Follower
Jul 17, 2017
LB1120 not valid on Verizon
I have several lb1120 LTE routers...There are several issues that need to be resolved...
First, these are unknown devices in Verizon system so cannot be activated directly... you need to have another supported data device that you can activate the SIM on then you have to move SIM to the netgear.
This works okay on Verizon consumer plan.
But on Verizon business plan... the netgear gets deactivated by Verizon because the lb1120 is not a supported device...verizon has shut off my modem several times and say I need to buy Verizon devices..
Netgear LB1120 is not officially supported Verizon, so system continually deactivate my modem/router.
Please help.
