elvisimprsntr
Mar 11, 2017Aspirant
LB1120 Public IP Address and DyDNS
BACKGROUND I have a LB1120 with an ATT IoT SIM card installed. I can connect to ATT LTE service. My LB1120 is in bridge mode, which presumably means it is IP pass thru mode. Unfortunately, ...
stevesw
Mar 12, 2017NETGEAR Expert
Hi,
As you stated, when in bridge mode, the LB1120 will pass thru the IP address rec'd from the LTE network.
Whether that IP address is public or private will depend on how the APN used is setup by the network operator.
From the table you provided, the ATT IoT APN will provide a private IP address.
To obtain a public IP address, you will need to contact ATT about getting your subscription (SIM) updated to use a different APN.
Steve
gloomymonkey
Aug 26, 2017Aspirant
Hi,
My LB1120 is in Bridge mode and it's passing a private network (10.207.163.44) to my router. My router's LAN is set to 192.X.X.X with DynDNS setup. LTE service is working fine, but i can't use FTP (from outside/public) with router's port forwarding to a PC. This is working fine when using Comcast modem.
